is there any mx worthy kits
Old Jul 18, 2003 | 11:32 PM
dsracer666's Avatar
Default is there any mx worthy kits
motor work! more hp down low. I know a lot of you guys have the big carbs and big bore kits but I don't need much more top end. maybe a higher rev out!
is it posable to get Ti valves?
any help would be thanked
Old Jul 19, 2003 | 03:24 AM
SpinCycle's Avatar
The easy way to move the power down is to gear down, go with a 14 tooth front sprocket. That will put some juice in it [img]i/expressions/face-icon-small-smile.gif[/img] Other than that just go with the standard mods, filter, pipe, etc..
Old Jul 19, 2003 | 04:47 AM
MudStud's Avatar
Here is what I would do and DID!
HC piston, 11.5 that way i could run pump gas..
A1/A2 cams or the 109/110 cams from web.. I like the a/1/a2 personally.
LECTRON 46 HV carb!!!!
That babby has TONS of downlow power!!! I have it and LOVE IT. It has near fuel injection responce and it flow HIGH on top and perfect down low..
Look back a few days ago and look at my post on my rebuild.. I persoannly think its a SWEET setup.
Old Jul 19, 2003 | 08:41 AM
BillDS650's Avatar
dsracer666 you can cut track time by 5+ sec per lap with new shocks, A-arms and -1 inch swingarm.
Old Jul 19, 2003 | 11:35 AM
TyreSpinner's Avatar
Umm, carbs usually have better response than Fuel Injection...in most cases...
Old Jul 19, 2003 | 12:00 PM
Hightower's Avatar
I am very similair to mudstud's setup, same cams, and the low end and midrange is absolutely wonderful. holeshots that make bystander's jaws drop. the accel pumper on the TM42/45 carbs is amazing, giving a boost on holeshots like I never imagined until I finally installed it. this motor, combined with Bill's chassis recommendations would yield an awesome ds mx'er.
definitely gear down, 15/40 or 14/40, depending on tires, rider weigh, etc.
Old Jul 19, 2003 | 05:06 PM
dsracer666's Avatar
the only time I really need the power down low is at the southwick track, coming out of the corners I would like more power because the sand just robbs it!
suspension is for next year for the B class!
as for the hole shot I all ready get it! every time[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 19, 2003 | 07:36 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
my stage 2 was the most powerfull for the money and reliable, everything else is a big money pit!!!!!
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Alex G.
Sep 16, 2015 12:13 PM
Lou Domenech
Sep 11, 2015 06:35 PM
Sep 10, 2015 01:56 AM
Elkaholic
Sep 6, 2015 02:44 PM
