Overheating???
Old Jul 20, 2003 | 03:57 AM
goldy103's Avatar
Default Overheating???
I have heard that several people say that the v-force overheats easily and you cant go top speed or push it to its limits do to overheating. Is this true???
Old Jul 21, 2003 | 12:12 PM
green700's Avatar
I've been to the sand dunes 3 times and each time it was 100 F and sand is not easy terrain. My temperature warning light has never come on, but the radiator fan is always humming and it's on a thermostat so I think the engine was warm but not overheated. Based on what I've seen in the soft sand, there is no way you could overheat that thing on dirt unless the radiator was clogged with mud. Driving at top speed will actually cool the engine down, not heat it up cause you get a lot of air passing through the radiator. It's like a car, more likely to heat up in stop and go traffic than top speed.
Old Jul 21, 2003 | 12:54 PM
trx450's Avatar
I ride mud, and the fan runs a lot. In my case the radiator DOES get partially clogged, but I just go to a waterhole, or creek, and throw water at the raditor to clean it off and I'm good to go !
I BELIEVE that , in the owner's manual, they discuss the red "temp" light, saying that the lamp comes on BEFORE actual overheating occurs. That is a nice feature, in my case, I would start hunting a radiator cleaning area! Mine hasn't come on, either.
Old Jul 21, 2003 | 04:34 PM
goldy103's Avatar
Thanks for the info.
Old Jul 21, 2003 | 05:18 PM
Mudfoot's Avatar
My fan runs much less now that I've fattened up the jetting, when I was running lean it was on a lot. The dynojet kit from rockymountain is a pretty good $50.00 investment I think.
Jenn1
Sep 8, 2015 09:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
cornermike
Jul 30, 2015 06:37 AM
