GRIZZLY BELT QUESTION?
Old May 19, 2000 | 12:58 PM
Jamie's Avatar
When my Grizzly reaches 30 mph it starts reving high but will not go any faster. I dont know if it is my belt or what? Has anyone else had this happen to them or know what is causing it?
Old May 19, 2000 | 01:29 PM
Ridgerunner's Avatar
Did you happen to get it wet? Could be water trapped in there and causing your belt to slip.
Check you manual for the drail plug locations and drain it out. From what I have read there are 2-3 drain plugs.
Or you could stand it up on its back rack and just let it sit a while. Make sure your turn off your gas first through. This also will drain off the water.
If thats what it is causing the problem.
Old May 19, 2000 | 07:01 PM
grizlyman's Avatar
how old is the machine? if more than 1-2 years i would check the belt. when you get a new one you can really feel the diffrance.
Old May 19, 2000 | 07:43 PM
Jamie's Avatar
My Grizzly is a 00' with 1100 miles on it. I took the cover off and the belt is very dry. I dont know if you can tell by looking but it looks ok to me.
Old May 20, 2000 | 10:27 AM
grizzzzzz's Avatar
i have a 99 grizzly with 400 miles on it my brakes were adjusted to tight when i first picked it up . but i would say if there isn't any water in there it's your clutch, carb or transmission it would be interesting to know what you find out
todd
Old May 22, 2000 | 04:48 PM
Daks's Avatar
check the buttons in your secondary clutch. sounds like it is not opening and giving you your higher range
Old May 25, 2000 | 10:04 PM
mung2000's Avatar
dont you have a warranty bring it back! I have a grizz and it smokes.
mung2000's Avatar
Old May 26, 2000 | 01:28 AM
Deej's Avatar
I would have to agree with Daks. Sounds like a clutch problem. One or both of the clutches (drive or driven) is not moving as it should.
DJ
RedRancher
Oct 15, 2020 01:45 PM
merryman
Sep 6, 2015 10:20 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
toonces
Jul 31, 2015 09:27 AM
toonces
Jul 11, 2015 12:01 PM
