lakota and mojave owners.............smoothy hood
Old Jul 21, 2003 | 05:17 PM
lakotasportrida's Avatar
Default lakota and mojave owners.............smoothy hood
I was wondering where the ignition switch goes once you put on a smoothy hood and what else needs to be done for it to fit.Also where can i get some heavy duty clutch springs for a lakota.My lakota isn't starting either and i don't know what is wrong i checked the wires put fluid in my battery and charged it check the spark plug and don't know whats wrong it isn't the starter it cranks fine when i put a battery charger on it,but when off it just won't crank it makes a click,then won't do nothing else.Any help would be nice.
Old Jul 21, 2003 | 07:14 PM
ringer's Avatar
When you put a smoothy hood on you un plug your light and ignition.Once they are unplugged allyou do is start it .That is on a mojave.You dont need the key any more just put switch on run.
Old Jul 21, 2003 | 11:38 PM
Thanks for the info ringer.Someone else has to know.
Old Jul 22, 2003 | 12:59 PM
Anybody.
Old Jul 22, 2003 | 01:15 PM
mahnster's Avatar
ringers right.
Old Jul 22, 2003 | 03:34 PM
boob's Avatar
you dont need the key besides for saftey, all the key does is complete a cut-off circuit, when its on the ON position the shut-off circuit is not complete, when its on the OFF position the shut-off circuit is complete. this means if you take out the entire key system the shut-off circuit wont be completed therefore the quad will start, also your starter tihng is prolly a faulty ground, silinoid(dont know how to spell) or you need a new battery
Old Jul 22, 2003 | 03:50 PM
Thanks for the help,so all i need to do is unplug the light and ignition and i do need a new battery.
Old Jul 22, 2003 | 06:30 PM
kybabyn's Avatar
where can i get a pick of the smoothy hood for a mojave and how much did it cost?
Old Jul 22, 2003 | 06:44 PM
ringer's Avatar
Maier plastic has them for 45.THey dont have a picture available yet. But you might want to ask someone else.
Old Jul 22, 2003 | 06:49 PM
boob's Avatar
look at the galleries in www.kawieriders. com
