DG Module have hesitation
Old Jul 21, 2003 | 05:38 PM
VTprairie's Avatar
Default DG Module have hesitation
Ever since I did my spring and stuff always had a slight hesitation on takeoff which was really no big deal but now have the holeshot and don't want to lose anything from it on takeoff any sugg's
Old Jul 21, 2003 | 10:46 PM
NovaKaw650's Avatar
Th Holeshot will probably get rid of the slight hesitation.
Old Jul 21, 2003 | 10:49 PM
nyroc's Avatar
The needles might be lean. Does it hesitate less when hot (lean) or cold (rich)?
The Dynojet needles made mine stop hesitating, but you can make the stock needles work fine with shims.
The holeshot ccertainly will improve it, but you might as well tune it right. Doesn't matter before or after the holeshot.
Old Jul 22, 2003 | 10:11 AM
VTprairie's Avatar
honestly don't remeber how much hesitaion was there before I put the holeshot in now I am paying more attention and there is a slight one I have 3.5 turns on my mixture screws wonder if to rich for the summer?when I do snap the throttle and there is no or little hesitation it really snaps and it will wheelie even with me on it (370 pounds).it wheelied before but mostly in low range.Nyroc I have .050 in shims do I need more or less, the problem is not that big but don't want to lose any power.
Thanks
VTprairie's Avatar
its worse when cold
Old Jul 22, 2003 | 11:28 AM
nyroc's Avatar
You might wanna try going up a bit on the shim thickness to see if it improves the response.
Old Jul 22, 2003 | 01:45 PM
VTprairie's Avatar
I had my dealer do it before how much do you think i should try all the #4'S I found were .025 thickness and what kind of job is it to just shim the needles
Old Jul 22, 2003 | 03:47 PM
VTprairie's Avatar
just went out and played around in the yard and the hesitation is only really preasent in high range not in low range I actually feel alot more diffrence from stock to this module in low range not in high,by the way had my bike overheat last weekend had some mud in the rad, ordered the low pressure washer from highlifter and works pretty slick and fits in the storage comparment not bad for 40 bucks
Old Jul 22, 2003 | 04:08 PM
Haynes1111's Avatar
Post when you use your low pressure washer to clean an overheating radiator and let us know how well it works. I overheated this past weekend from riding in the mud. Would have loved to have that with me.
Old Jul 22, 2003 | 08:07 PM
VTprairie's Avatar
I have an 18 foot round pool that's were I tested it when I puit it together and it will go the 18 feet across the pool but if you put you hand close to it it doesn't sting when i use it on the trail I will let you know also got the heat fighter kit from highlifter going to put that in as well for the rad and oil also putting the water temp guage on also don't like reling on that light
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
hueby
Nov 6, 2015 11:34 AM
house1
Aug 9, 2015 10:49 PM
Austins
Aug 9, 2015 02:28 AM
D-Hagz
Jul 4, 2015 02:19 AM
