putting brakes on 300EX
Old May 22, 2000 | 07:35 AM
taioh25's Avatar
Need help im putting brakes on the rear of my EX but the piston in the caliper want go all the way in what can i do to get it all the way in. Could i take it apart and get it in like its suppose to be?
thanks
Old May 22, 2000 | 08:52 AM
SUP440's Avatar
Sometimes I have to use a c-clamp to push the caliper back in.Any more than that and you have a serious problem that your dealer should probably fix.I wouldn't recommend taking it apart.
Old May 22, 2000 | 10:18 AM
THEXOTIC1's Avatar
If it is the rear caliper the emergency brake could be stopping the pistion from sliding all the way back. I also use a clamp to push the pistion back in place.
Old May 22, 2000 | 03:39 PM
Y2K300EX's Avatar
Yes back out the Emergency Brake bolt then use a C-Clamp to push it in. I had the same problem.
Old May 22, 2000 | 10:53 PM
hondatrx300ex's Avatar
lol I had the same problem! I thought it was the parking brake so I took it off then I think I used a big screwdriver and pryed the piston down. when I got the pads on it rubbed the rotor a little until it wore a little. later
Old May 23, 2000 | 06:28 PM
taioh25's Avatar
Thanks for everyones advice i did back the emergency brake bolt out and it work perfect.
thanks again everyone
Sjrpp
May 2, 2023 03:59 PM
toonces
Oct 16, 2019 12:11 PM
Sjrpp
Jul 5, 2015 09:04 PM
