Woops...
Old Jul 29, 2003 | 12:11 AM
Rebel21's Avatar
Default Woops...
ok i dont know if i did somehting wrong but i think i did, when i wheelie i pop the clutch in 2nd gear on my warrior and it comes right up ( i pop the clutch becasue i cant wheelie with out doing that i can bring it up by just givin it gas and pulling up) but now it will not wheelie AT ALL in second gear but it will in first it does now have close to as much jump when i pop it anymore whether on pavement or grass could i have stripped the gear? another questionwhen i get it up in first and i shift to 2nd in a wheelie do i use the clutch to shift or no?
Thanks a lot.
Old Jul 29, 2003 | 12:42 AM
Treeshot's Avatar
Default Woops...
99 warrior? Is that the stock clutch in it? Might wanna check the clutch plates they might be slipping. How much tread is on your tires now compared to when it came up easily in 2nd? Both things are assuming this happened gradually. Did this happen all of a sudden or over a period of time?
Old Jul 29, 2003 | 09:18 AM
Rebel21's Avatar
Default Woops...
my tire tread is a little bit moe worn but not a lot, so i dont think it is the tires, but i will check the clutch plates. thanks
RotGutBottom
Jul 23, 2001 12:55 AM
