Techtronics Race Dash
Old Jul 31, 2003 | 11:16 AM
Delmustator's Avatar
Default Techtronics Race Dash
This is an interesting addon that I ran accross. It may be a nice addition to the V-Force.
Techtronics Race Dash...
Picture of the Race Dash
The Techtronics Race Dash is a combined digital tachometer and temperature display. The Dash uses the latest LED and display filter technology to provide excellent contrast and viewing in all light conditions.
In addition to the basic display there are a number of functions that can be easily set using the menu buttons on the faceplate. A 4-stage shift light display can be set to operate at your shift point. The shift lights can also be programmed to alter the RPM intervals between LED's to tune their 'sweep speed' during acceleration.
Other features include 8 levels of brightness control, variable pulse count settings so you can choose to take the signal from the negative side of the coil or the original tacho output, which often put out different pulse rates. On a Yamaha R1 for example you run the pulse setting at 1 if picking the signal off the coil, and 2 if using the original tacho output.
The Dash also has 45 minutes of recording ability and this can be switched on or off through the button controls. When in replay mode all the activity, including temperature, is replayed in actual speed and you can rewind or fast forward within the replay to view the session.
Race Dash Specifications
[^] Size 185 x 80 x 23
[^] Weight 200g
[^] Material Carbon Fibre & Acetal Plastic
[^] 3M Optical Filter Display
[^] RPM & Temperature Display
[^] Programmable Shift Lights
[^] 45 Minutes Of Recording / 8 Brightness Settings
[^] Variable Pulse Signal Pickup Settings
The Dash is available in the following scales:
0 - 8,000 RPM
0 - 9,000 RPM
0 - 10,000 RPM
0 - 11,000 RPM
0 - 12,000 RPM
0 - 13,000 RPM
0 - 14,000 RPM
0 - 15,000 RPM
0 - 16,000 RPM
The Techtronics Race Dash is supplied with a full fitting harness, temperature sensor and instructions.
U.S and Canadian sales are now handled by Williamsville Competition - an authorised Ducati dealer for over 20 years.
Please contact Al Gillen to discuss your requirements.
E-mail WCompetition@aol.com
Web Site www.worldbikes.com/wcompetition
182 South Main Street Holland N.Y. 14080
Tel: 716 537 2534
Fax: 716 537 2855
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Sep 1, 2015 01:45 AM
