-Warrior-Help Me!!
Old Aug 4, 2003 | 04:25 PM
ArchFire's Avatar
Default -Warrior-Help Me!!
I need help with my Yamaha Warrior it just stoped working after 2-3 weeks
the carb is blowing air into the air filter rather than sucking air the pistons arent getting gas is there anything i can do?!?!?!? please help
Old Aug 8, 2003 | 05:02 AM
c3coupe's Avatar
sounds like you have a stuck intake valve! lots of fun to pull the motor down.... not really that bad though. it should be an easy fix, except for the damage that it might have to the piston if the two hit very hard. new piston and rings around 90 bucks or so, gaskets around 50bucks for all the top end you'll need, and whatever got hurt if they hit while it was stuck open.
Old Aug 10, 2003 | 12:37 AM
ArchFire's Avatar
there was new piston rings put in it about 2 months ago,, i took down the head and looked at it and it looked fine to me its has to be somthing with the carb beacuse i looked at it and it wasent getting any gas to the piston,, also i took apart the carb to clean it and some of the jets where stuck i got a new jet into it and it spits gas into the piston "But" it just wont kick over it wants to but still wont,,
any info on what else needs done?
