loose A arm ??
Old Aug 5, 2003 | 07:05 PM
viperstripe's Avatar
Default loose A arm ??
I have a 2001 500 4x4 scrambler and i had it up on a jack and i noticed that you could push the front left a arm back and forth about an inch. is this normal or did i loose a bushing? And what tools do you need to take tires off rims and put new ones on ? is it easy?
thanxs for any help
Old Aug 5, 2003 | 09:34 PM
highwayman's Avatar
I think you lost a bushing, check out http://www.partsland.com/ they have real good diagrams showing what was there stock.
Old Aug 6, 2003 | 12:38 AM
BigBadScrambler's Avatar
some tire shops will put your tires on for you. But if you do it yourself, you need a tire iron. It is not the easiest thing to do, especially if you have 6 ply tires. It took my about 1 1/2 hours to put my X/T's on my rims even when useing the tire changing machines at school
Old Aug 6, 2003 | 12:48 PM
NCScrambler's Avatar
Yep, sounds like you lost a bushing. Some aftermarket has beefier ones, but I can't think of who at the moment. The same thing happened to me one time and I went back factory, but I would get a better one if possible.
Old Aug 6, 2003 | 01:07 PM
Farmr123's Avatar
The high-strength bushings are available at HPD (hope I got the link right)
Farmr
MeadowlarkFarm
Nov 27, 2019 08:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
jankerstien
Sep 21, 2015 03:09 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
