Stock bore mods to make a beast!
Old Aug 6, 2003 | 12:45 PM
BigScary's Avatar
Default Stock bore mods to make a beast!
What could I do to mine to make it faster?......
it was fast enough tha last time I went into the motor now I want more.......
it has to be reliable because I ride alot.......
alot of people recomend new carbs?..which ones and what will I gain?
what else?.........I would like to stay with a stock bore if I can but if I will gain alot I would go to a larger bore........
help me out here.
Old Aug 6, 2003 | 01:00 PM
BigScary's Avatar
bump
Old Aug 6, 2003 | 01:10 PM
14mins's Avatar
FCR's will not give you instant HP. What have you done to the stock bore? 12-1, stage 2 cam?? I just noticed your mods. I would put a 12-1 in there. That will be the biggest gain for the buck there. A aftermarket air intake would help. Sixsixt has one as well as velocityraptor. Check them out
Old Aug 6, 2003 | 01:24 PM
warrior620's Avatar
You could go w/ a higher comp. piston and an after market ignition setup. Correct me if I'm wrong but I think your motor has to be pretty built to get the most outa bigger carbs. There are a few guys on here that run the edelbrock system though and love it.
Mike
Old Aug 6, 2003 | 02:06 PM
whitebread's Avatar
YES,WHAT 14MINS SAID!!
Old Aug 6, 2003 | 03:32 PM
PatsRaptor's Avatar
Going with a larger cam also will gain you more on top and there are now a few BIG cams out there!
Pat
Old Aug 6, 2003 | 03:45 PM
BigScary's Avatar
would I be better off with a stage 2 hot cam or a more aggressive web cams?..........
I don't want to go to the 12:1 piston cuz I will have to run race gas.......
I ride too much to have to run race gas all of the time......that would get expensive........
If I put in a top end cam will that kill my bottom end?......I do like to ride wheelies.....LoL
Old Aug 6, 2003 | 03:49 PM
BigScary's Avatar
what do you mean a different air intake?
Old Aug 6, 2003 | 03:53 PM
Hiram's Avatar
Originally posted by: BigScary
would I be better off with a stage 2 hot cam or a more aggressive web cams?..........I don't want to go to the 12:1 piston cuz I will have to run race gas.......I ride too much to have to run race gas all of the time......that would get expensive........If I put in a top end cam will that kill my bottom end?......I do like to ride wheelies.....LoL
Yes, it will...I put a stage2 cam with a 11.1 piston and lost alot, and I mean alot of bottom end, stage2 or high rev cam needs 12.1 to help bring back some of the lost bottom end, my power is almost 2 stroke like but when it comes on, you got to really hold on.
Old Aug 6, 2003 | 03:54 PM
biggerisbetter's Avatar
Bess stay were you are at then[img]i/expressions/face-icon-small-wink.gif[/img]
If you want to go FAST then you will need RACE GAS. Bigger cams will help ,some(not alot), and will take away from the bottom what it puts on top.
The only thing I would suggest for you is to invest in a nice NOS system, for those times when you want to drag race your buddy's.
Bigger.
