confused!
ok i have a completly stock trailblazer 400 whats a good starting mod that i can save up for it i don't want rcr kit stage one unless some tells me what gains do i get out of it i want to see if it's worth the money people said i wouldn't get any gains from vforce reeds what else is there to truly get??????????????????????????????????????????????? ?????[img]i/expressions/face-icon-small-confused.gif[/img]
The absolute least amount of money you could spend and see a descent increase in power is to ad a HPD trail pipe (which will to factory muffler ) The pipe comes with jets for $205 . Also ad a HPD plain clutch spring for $20 . With shipping and all this would total at $233. The Hpd plain clutch spring is what is in a HPD clutch kit and you could always get the rest of the kit later as your wallet allows . I recomend the clutch kit highly , but just the spring alone is a step in the right direction .
Another approach is adding a silencer $70 , a different filter set up (RcR hiflow airbox kit) $35 and a jet $3. This set up with shipping would cost about $115.
The $233 set up would ad about 8 to 9 horses .
The $115 set up would ad 3 horses.
With either kit as a starting point when it came to going to the next level all of the parts purchased would not need replaced as you went further into modifying your machine .
If the more expensive kits are out of your price range and you must *piece* it together , buy parts that don't need tossed out when you go to the next level .
Rick
Rick
