cutting scrambler plastic?
Old Aug 8, 2003 | 10:49 PM
scrambler420's Avatar
Default cutting scrambler plastic?
im thinking about cutting my plastic but i dont wanna mess it up..i dont wanna cut off to much
anybody have any tips on how to cut them and have them match?thanks
Old Aug 8, 2003 | 10:54 PM
scrambler123's Avatar
i also am thinking about cutting my plastic. the only thing that is stopping me is the different cuts that would have to be made on each side to retain the heat shield. but i may be upgrading to a race style pipe in the future then ill cut them.
Old Aug 8, 2003 | 10:55 PM
hotseatperformancefan's Avatar
with a marker draw out a line to cut on and take your time. makesure you take your time because if you mess up its gonna look stupid.
Old Aug 9, 2003 | 12:23 AM
RuckusRacing's Avatar
Heres how I cut my plastic:
1. Decide where you want to cut it at.
2. Once you decide take 3/4" masking tape and lay along the line where you want the cut to be.
3. Now take 2'" masking tape and mask the plastic inward (helps protect it when you start to sand)
4. I use a sawzall with a fine tooth blade (a jig saw will work too) I try to keep the cut about 1/8" away
from the edge of the tape.
5. Take a sanding block with 120 grit sand paper and start to sand the plastic edge. Make sure to keep
the block vertical and just sand the very edge of the plastic.
6. Once it starts to smooth out switch to 180 grit then 220..320..400..600 and finally 1000 grit.
7. Once your done with 1000 take all the masking tape off and I usually finish off the edges with 1500
grit by hand.
The best advice I can give you is take your time!!! Look at other quads with cut plastic to help decide where to cut yours.
Old Aug 9, 2003 | 01:39 AM
ScRaMbLeRiZeD's Avatar
Use a dremel. Takes a lot less time to finish once you draw out your lines.
Old Aug 9, 2003 | 01:35 PM
modquad's Avatar
I do the same as Ruckus, but I use an aviation style metal snips. The offset style work the best, then just followed by a file and a sanding block.
Old Aug 9, 2003 | 02:25 PM
thanks guys..anybody have pics of their cut plastic?
Old Aug 9, 2003 | 02:33 PM
CED's Avatar
CED
I have a couple.I used tape to get both sides even then cut it with a jig saw,then filed the edges.
Old Aug 9, 2003 | 04:17 PM
i cut my plastic today it was very easy. i just drew some lines (make sure you measure from the outside to see if there even to keep everything symetrical) then i cut it with a dremel cutting disk it only took 10 minutes after drawing. it left a very smooth cut that required very little sanding a little with 150 grit then i finished up with 1500
Old Aug 10, 2003 | 01:25 AM
Told you how easy and fast the dremel is[img]i/expressions/face-icon-small-happy.gif[/img]
