Eton Viper Rev limiter???
Old Aug 12, 2003 | 04:41 PM
Wkndwaryrs's Avatar
Default Eton Viper Rev limiter???
Does a 2004 90cc Viper have a rev limiter & if so where might it be?? Thanx[img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 13, 2003 | 02:27 PM
markvette's Avatar
yes it does. the cdi is located under the left front fender. clip the green wire on the cdi and no more rev limiter.
Mark
Old Aug 13, 2003 | 02:31 PM
Wkndwaryrs's Avatar
Thanx, will try it
Old Aug 23, 2003 | 04:40 PM
Wkndwaryrs's Avatar
[img]i/expressions/face-icon-small-sad.gif[/img]Looked for a green wire , but none found. 5 wires total, Black w/white stripe, White w/blue stripe, Black w/ yellow stripe, Black w/ red stripe, & Black solid. Any ideas???
Old Aug 23, 2003 | 10:26 PM
mqr24's Avatar
we just bought a eton viper 90 2 days ago and the green wire is not a plug in. it's on the backside of the cdi under the mounting rubber . it will open it up when you clip it. hope this helps you out
Old Aug 23, 2003 | 11:57 PM
pigpen's Avatar
You will need to locate the CDI and remove the rubber sleeve around it. Once you the rubber
sleeve you will see the green wire loop on the back side of the CDI. On the 2004 the CDI is
located on the left side of the bike (if your sitting on it) just inside the body where the steering
column goes in from the handle bars. You can reach you hand down in there and feel it. You can
even pull it up and look at it without taking anything apart. It is a black box about 2"x3"x1".
Old Aug 26, 2003 | 12:41 PM
Wkndwaryrs's Avatar
Once again thanx, I found the green wire hidden as you said, seems to make quite an improvement in top end.
Old Oct 6, 2003 | 01:52 PM
fishslab's Avatar
Just bought a '02 Eton 90 Thunder. It is brand new, left over stock at the dealer. Would this apply to it as well?
Old Oct 6, 2003 | 02:38 PM
Scramblur50's Avatar
If it has the green wire, then, yes it would apply. Just akes a few seconds to look for the green wire.
Bryce
Old Jul 3, 2004 | 07:00 PM
B2base11's Avatar
I have a 2000 dxl 90 (made by eton) and i can't find the green wire...I took the rubber sleeve off and I could still not find it...and ideas??
