scrambler wiring question?
Old Aug 13, 2003 | 12:41 AM
scrambler123's Avatar
Default scrambler wiring question?
I removed my headlights and mounted up a set of fog lights instead my question is which color wire is the low beam wire? i believe the brown wire is the ground (correct me if i'm wrong) any help would be appreciated
Old Aug 13, 2003 | 01:03 AM
BigBadScrambler's Avatar
Brown is the ground. I am not sure which one is the low beam. What I did is wire the low and high beam wires together so the kights will come on when I hit high or low. Works good
Old Aug 13, 2003 | 01:05 AM
thanks a lot
Old Aug 13, 2003 | 02:32 AM
does anyone know which color is high beam and which is low beam?
Old Aug 13, 2003 | 03:58 PM
RookWV's Avatar
Email me at jamiev_03@yahoo.com.....I've got a couple of Adobe PDF files that might help you.....from an 03 manual....or this statement may be all you need....
Remove the headlight pod cover.
Probe the high beam headlamp plug wires (Brown and Yellow) at
back of connector.
Turn headlight switch on.
Test for battery voltage across the connections.
Old Aug 13, 2003 | 06:53 PM
does anyone know?
Cole Hadden
Jun 15, 2025 09:05 AM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
Chocobamofo
Jul 10, 2015 07:46 PM
D-Hagz
Jul 4, 2015 02:19 AM
