84 atc 250 R
Old Aug 16, 2003 | 11:29 AM
ATVman00169's Avatar
Default 84 atc 250 R
do you all think this is a good atc relible and such. i am thinking about buying it. its got craked fenders but the motor is all new and bored almost all the way. its got the bigest pisten winston makes in it. it does got room if i need to bore and sleve it. and its got corba pipe and DG silencer. any input in this matter would be most help full
thank you.
Old Aug 16, 2003 | 05:49 PM
dork's Avatar
yes those were quite reliable. the problem with something like that is, you don't always know what's been done, and if it has was it done right. for example, were the cases split and new crank bearings and seals put in along with the topend, or was it just a piston? ask the guy to find what exactly was done because of the age certain things are probably needed. also ask if he has rejetted to compensate for the bigger cylinder and pipe/silencer, otherwise that piston might not last too long. but if you can get it for cheap, $500 or less, go for it.
