will not run
Old Aug 17, 2003 | 09:37 PM
Fredinpa's Avatar
Default will not run
went through deep water and after that will not run above a idle. any thoughts. checked all oil no water or metal shavings.
Old Aug 17, 2003 | 09:45 PM
DirtDragon's Avatar
I would check the battery and double check the throttle min/max values to make sure they are correct. Other than that you will need a tester to check all the connections. Good luck!
Old Aug 17, 2003 | 09:46 PM
WISTECH's Avatar
Sound like water in the tps. Check it with a D&M kit or an ohmmeter. Cannondalers web site has the manuals for free online.
Old Aug 28, 2003 | 10:23 PM
Fredinpa's Avatar
found the problem water in the voltage regulator It shorted out so bad that it will drop the 12v out put to 6v as soon as it is conected.
Old Aug 28, 2003 | 10:44 PM
WISTECH's Avatar
Thats one for my diagnostic manual . It must have had a seal failure of the regulator because they should be fully sealed from water.
