bore and stroke
Old Aug 19, 2003 | 11:12 PM
roosthrower's Avatar
Default bore and stroke
How do you figure out displacement using the bore and stroke numbers? Also a bigger bore will result in more higher rpm horsepower and a longer stroke will result in more low end torque right?
Old Aug 19, 2003 | 11:25 PM
BigScary's Avatar
I think you are backwards.........bore = low end
stroke = high end
Old Aug 20, 2003 | 12:28 AM
SpDdEmOn's Avatar
go to www. b l u e t r a x x .com and click calculators on the left and then go to displacement calculator. Thats the only way I know how.
Old Aug 20, 2003 | 12:47 AM
selector's Avatar
pi x r squared x height = displacement (or volume)
YFZ450 = 439cc...
pi x (4.75 x 4.75) x 6.2
3.14 x 22.56 x 6.2 = 439.246
pi x (9.5cm x 9.5cm) x 6.2cm = 439cc
selector
Old Aug 20, 2003 | 01:29 AM
jed250's Avatar
Bore VS Stroke. Which would you prefer? Do you guys know why a huge truck can put out low RPM and still pull all that heavy stuff? Why is it that F1 cars put out really high RPMs and not be able to pull heavy loads?
A huge truck has a longer Stroke. It takes it a lot longer to make a cycle inside the cylinder so therefore there is low revving. An F1 car revs really high because it has a small stroke, but a huge bore.
exmotocrosser
Sep 13, 2019 06:12 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
