Shocks or Axle for Raptor
Old Aug 21, 2003 | 05:37 PM
SparksRaptorRider's Avatar
Default Shocks or Axle for Raptor
I was wonderng what should i buy first a axle for my raptor or a set of shocks? Also what type of shocks whould u go with?
Old Aug 21, 2003 | 07:02 PM
RacerRob's Avatar
Go with the axle first. I have a Durablue 2+2 and can't complain about it. For shocks, I run Works Performance and same results..no problems...[img]i/expressions/face-icon-small-cool.gif[/img]
Old Aug 21, 2003 | 08:04 PM
warrior620's Avatar
I would go w/ shocks, b/c they lower/widen your quad which in turn helps it handle alot better. It won't widen your back end for obvious reasons, but if you go w/ just the axle your back end will be wider than your front unless you flip the stock rims. With the back end wider it will tend to wash out more and ride up on burms instead of railing them.
Mike
Old Aug 21, 2003 | 08:07 PM
RacinJason's Avatar
Shocks!!
If you want an axle you should do a-arms as well unless you ride dunes only
with the axle and no a-arms the quad "pushes" through the corners
bmxatv10
Oct 14, 2022 06:23 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
1000gade
Sep 9, 2015 04:41 PM
