New C-Dale owner!!!
Old Aug 24, 2003 | 01:07 PM
bulldogz400's Avatar
Default New C-Dale owner!!!
Well I bought a 2002 Cannondale Speed!! Here it is...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2428527033
I thought it was a great deal and can't wait to find out what it is made of!!! Anything I should know about these bikes?? Thanks a ton!!
Old Aug 24, 2003 | 02:03 PM
wheelrider's Avatar
If you want to start it up to show your buddies make sure you run the engine for at least a minute before you shut it down because they run fairly rich and will foul the plug if you dont let it heat up and burn off the raw fuel. I would also suggest going to a hotter plug like a #8. Always use synthetic oil. Read the decal on the tank and believe it. Drain your coolant and run EVANs and check your valve cover for corrosion under the water pump and get it powdercoated if it is bad. When you do the stud update its a good time to get it done.
Old Aug 25, 2003 | 08:27 PM
thomez's Avatar
Glad to see you joined the family. I recently purchased an 03 Blaze. You might want to check out the information at both www.cannondaler.com and www.cannondaleriders.com . Both have manuals, info on the updates, and very helpful people. Once again, welcome to the family! [img]i/expressions/face-icon-small-smile.gif[/img]
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Customer Service #1
May 15, 2020 08:46 AM
wendal
Oct 31, 2017 03:31 AM
Ahtatu
Sep 28, 2015 12:14 PM
