prairie 700 can't decide 2wd or 4wd
Old Sep 4, 2003 | 02:30 AM
hardwood700's Avatar
Default prairie 700 can't decide 2wd or 4wd
Well 26yearoldbeginner i pulled off the clutch cover and blew out all the dust and in the process i flipped the belt wear indicator switch. i flipped it back but the belt indicator light keep flashing. i tried disconecting the battery but that didn't work. does anyone know how to reset the belt wear indicator.
i might end up having to take it to the dealer but i called him and he said that they have blown all the dust out of the clutch housing and that solved the problem and to give it a try if i wanted.
Old Sep 4, 2003 | 06:50 AM
therock's Avatar
Do a search here or go to http://atv.dnsalias.com/tipview.cgi
Old Sep 8, 2003 | 08:58 PM
Banach's Avatar
My friend had the same problem--there is a little black box on top of the clutch cover--disconect it--follow that wire towards front of vehicle--2 other connections are there in that loom--disconnect then & reconnect them in oppisite order--turn on key 4 about 10 seconds --turn off key--reconnect in original connectors--should be good 2 go
Old Sep 15, 2003 | 09:35 AM
Banach's Avatar
Well----did it work??
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
cboler9
Sep 24, 2015 08:35 PM
PrairieDog126
Sep 12, 2015 05:23 PM
Rick Van Matre
Sep 11, 2015 11:52 PM
