Question about Raptor valve adjustment..
Old Sep 5, 2003 | 05:26 PM
PipeIt660's Avatar
Default Question about Raptor valve adjustment..
I checked my valves a few weeks ago, and the intakes were fairly tight.... so I adjusted
them to the high side of the tolerance and the bike ran great. My question is ... when I
was sizing the gap between the rocker arm and the valve, I noticed the gap was not a parallel
mating surface. When I had the feeler gauge in there, it was contacting on one point only, not
the whole surface. Is this typical ? Sorta like this :
Rocker --> | | <-- Valve would be parallel. Mine was Rocker --> / | <-- Valve
One side of either the valve or rocker, was beveled, and the gauge only contacted at the tip of one of the
flats. All 3 intakes were like this. I searched , but never found that info anywhere on these boards, so
I figured I would ask. Thanks for any reply. Everything runs great, just wasnt sure if this was a sign of wear
or normal.
Old Sep 5, 2003 | 05:34 PM
sixsixT's Avatar
The bottom side of the adjuster that contacts the valve is rounded. Valve---> |( <---adjuster a little more like that.
Old Sep 6, 2003 | 12:19 AM
PipeIt660's Avatar
Thanks SixsixT ,
Thats probably what I was feeling. For some reason I had in my mind that it would be a flush mating surface, and
when it wasnt, I was like "mmm". Thanks for explaining, makes sense now.
Thanks again.
Old Sep 6, 2003 | 11:34 AM
HappaRap's Avatar
Lazy Boy Rider!
When I adjusted mine I had the same question, felt like the adjustment was contacting only on one side, so thanks for the info sixsixt.
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
yambam13
Jul 4, 2015 01:49 PM
