Tired of popping and dying at idle.
Old Sep 6, 2003 | 07:56 PM
whereisthemud's Avatar
Default Tired of popping and dying at idle.
The Prairie 650 runs fine but seems to pop alot at idle. No backfiring just popping and stuttering. At speed it is fine. I always need to choke it to start it no matter the temp. I assume I need to adjust some carb settings but unsure as to what. Any ideas?
Old Sep 6, 2003 | 09:07 PM
STAKK's Avatar
Turn the air/pilot screw's in (clockwise) until they seat, then turn back counterclockwise 2 1/2- 3 turn's out.......
Old Sep 6, 2003 | 09:45 PM
therock's Avatar
YES, Stakk is correct. As per his recomendation to me it worked wonders @ 2.5 turns in north GA.
I will add that if your popping is durring engine breaking when the throttle is shut, your idle may be too low starving the motor for air. Bump it up a little bit.
Old Sep 6, 2003 | 10:31 PM
Cool, I'll try that. Thanks. I don't have any popping during braking only at idle. I'll let you know.
Old Sep 9, 2003 | 06:28 PM
Well I checked it out and the rear carb was at 2.75 turns out and the front was at 1.5 turns out. That was set at the store and is the way I have been running it. I changed this to 2.5 turns out front and rear. So by turning it in vs. out, which way is giving you more air? In or out? Out I would believe.
Thanks...
Old Sep 10, 2003 | 03:24 PM
STAKK's Avatar
Out is richer=more fuel....In is leaner=more air, having them the way they were was probably throwing the carb sync off, stock is 2 1/4 turns out, 2 1/2 turn's out is a hair richer, should be fine there.....
Old Sep 10, 2003 | 04:08 PM
KevinM's Avatar
Make sure both of your carb boots are sealed tightly to the carbs.
slowgsxr97
Mar 18, 2022 03:40 AM
Karas3434
Aug 3, 2015 09:17 AM
binky79
Jul 30, 2015 06:37 PM
ghost civic
Jul 19, 2015 10:13 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
