Installing pink spring???
Old Sep 8, 2003 | 06:36 PM
Kramerica's Avatar
Default Installing pink spring???
Is the pink spring difficult to install? Are there any special tools needed. Any tips?
Old Sep 8, 2003 | 06:45 PM
green700's Avatar
I think the main bolt is 20mm. You have to hold the clutch still to remove it (reverse threaded) so you need something to brace it, unless you have an impact wrench. It should only take 15min to remove and 15 min to intsall. The clutch cover is easy to remove. After that you're looking at 8 little bolts and 1 large one in the middle.
ReconBayou
Oct 31, 2022 05:37 PM
shimanok2
Jan 29, 2016 07:37 PM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
2many2ride
Sep 27, 2015 04:35 AM
