how the Fu@# do you get the intake manifold off, that upper bolt???
Old Sep 10, 2003 | 09:43 PM
jetjock16's Avatar
Default how the Fu@# do you get the intake manifold off, that upper bolt???
guys how do you get that upper allen bolt out, the engine mount and bolt angle make it look impossible!! please help!
Old Sep 10, 2003 | 10:06 PM
SANDMAN430's Avatar
they make these allen wrenchs with round ends, you will love them for that bolt[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 10, 2003 | 10:13 PM
DSJOBBER's Avatar
Yep the good ole round ended allen key will do the trick. It still may be a pain in the **** with it though, if the bolt is real tight. Be prepared for some possible frustration though. I thonk I used a set of vice grips to hold the allen key better. Carefull strip the screw and your really f'ed.
Old Sep 10, 2003 | 10:22 PM
DSjockey's Avatar
Don't want to strip the bolt head, use a ball end hex key and a cresent wrench on the short end to get leaverage, have a friend grab the intake and turn counter clockwise as you turn the hex key, easy?
Old Sep 10, 2003 | 11:07 PM
buttfungus's Avatar
Yep, I used a ball end allen wrench and crecent/vise grips. Hold your mouth just right, and she will come loose![img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 10, 2003 | 11:25 PM
MudStud's Avatar
Yep, ball nose allen. I used a cressent just like everyone else. I did however put a lot of preasuer on the allen so it would not pop out while turning it.
Old Sep 10, 2003 | 11:28 PM
northjeepster's Avatar
I just put a bend in my allen wrench and I got it and out fine.
Old Sep 10, 2003 | 11:36 PM
jetjock16's Avatar
well guys, thanks for the help, tommarow ill head down to the hardware stores and look for a "ball end allen wrench", not sure what im looking for though, what does this thing look like, is it a long allen wrench with a pivot joint or something, or is it just a long allen wrench, rounded off at the end to kind of work into the bolt at an angle?... dont think ive see anything like that before?
Jetjock16
Old Sep 10, 2003 | 11:53 PM
SANDMAN430's Avatar
go to sears they will have both types on the wall, you will see what we are talking about right away. buy a better quaility type, i broke one off once and it was a pain to get out. if you can find a snap-on truck buy one on a socket end so you can use it to torque a lot of things on the engine.
Old Sep 11, 2003 | 12:05 AM
DuneMe's Avatar
What do they look like. . . next time you go to the bathroom. . . look down.
They kinda have a mushroom look to them.
