circlip fell into crankcase!!!
Old Sep 13, 2003 | 03:13 PM
willjoe86's Avatar
Default circlip fell into crankcase!!!
Alright-Im really in a jam now- I was replacing the piston on my 250x, and I dropped a circlip into the crankcase
Now what? Do I really have to split the cases? Or maybe I can stick a magnet in there? Or will it sink to the bottom and maybe I can somehow get it out of the oil drain hole????
I would really appreciate it if anyone has any ideas
Thanks in advance
Will
Old Sep 13, 2003 | 03:17 PM
Atkins450's Avatar
no harm in trying the magnet for an hour or two!, just make sure the magnet is tied tight and MAKE SURE you get that clip out, if it means not riding the thing for a year till you get it out, then do it.
Old Sep 13, 2003 | 03:22 PM
willjoe86's Avatar
thanks atkins
anybody else have any ideas??
Will
Old Sep 13, 2003 | 03:52 PM
2003warrior's Avatar
Is there any way to tip the motor upsidedown then jiggle it out?
Trying that would be a lot easier than slpiting the cases. IMO
Old Sep 13, 2003 | 03:55 PM
timmyboy450's Avatar
get one of those telescopic magnets at your auto parts store.
good luck.
I DONT RIDE FAST I JUST FLY LOW!
Old Sep 13, 2003 | 04:16 PM
Atkins450's Avatar
if you tip the motor upside down, it is still going to stick to the side because of the oil.
good idea timmyboy
Old Sep 13, 2003 | 04:30 PM
RacinJason's Avatar
flush the crancase with deisel fuel and try dumping the part out...next time stuff rags around the rod...
Old Sep 13, 2003 | 06:22 PM
screaminchief's Avatar
go to a good store with a good tool selection and find a mechanical finger...its flexible thin and should reach in there no prob...its not that expensive either...and after that you'll find that you have a thousand uses for it...also can be magnitized!
Old Sep 14, 2003 | 11:39 AM
evhwg's Avatar
kind of late now but your suppose to put a rag in the hole untill your done.
Old Sep 14, 2003 | 06:57 PM
devocorky's Avatar
the best bet is to flush it, with diesel.
