Lakota dead
Old Sep 13, 2003 | 05:08 PM
mgp007's Avatar
Default Lakota dead
Ok I go to crank it after several months of sitting. I choke it, give it a couple swigs of gas with the throttle and pull a few times b/c the battery is dead. It cranks and sputters and idles way up so i back off the choke a bit and it runs ok to be stowed up like it is. Then, I figure I need to drain the carb bowl so I do so b/c it sounds like it may have some water in it. Then, I pour some water remover in the tank and fill it up with gas, spilling some as usual.
I poured a glass of water over the fill cap to rinse it off and it ran down under the handlebars. Now, it won't even fire. Could I have fried something with the water? What the heck did I do? No fire whatsoever...
'98 Lakota
stock
Old Sep 14, 2003 | 01:19 AM
BigChris's Avatar
Default Lakota dead
Hmm...drain everything I would say, Deff. replace the battery, but try a new spark plug, that could be your problem......
Old Sep 14, 2003 | 07:58 PM
mgp007's Avatar
Default Lakota dead
Well it finally cranked. I don't know what it was. It just decided to crank, but it sputters bad and will backfire most of the time when I go to give it gas fairly quickly. Maybe that's the water remover?
Old Oct 4, 2003 | 02:09 PM
lillakota132003's Avatar
Default Lakota dead
i agree drain everything. not much i can say 4 the fact that im 133 but if u cant fix try takin apart ur enigine then jsu flush everything!!
Old Oct 4, 2003 | 05:48 PM
mojave250man1's Avatar
Default Lakota dead
does it feel like it wants to shut off when u rid it???
pgamboa
Dec 24, 2023 11:52 AM
slowgsxr97
Mar 18, 2022 03:40 AM
DM2015
Sep 7, 2015 10:36 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Hondamx751
Aug 13, 2015 01:06 AM
