dial-a-jet for vforce
Old Sep 14, 2003 | 07:19 PM
ansible's Avatar
Default dial-a-jet for vforce
where can i find a good online store that sells these for my v?
Old Sep 14, 2003 | 09:03 PM
PROS's Avatar
I seen them an ebay for $79 good luck o4 kfk orange 02 kaw 650 p read
Old Sep 14, 2003 | 10:45 PM
Oxygen's Avatar
I ordered mine from Rocky Mountain, Dial-A-Jets do seem to work, but if the V-Force
has the same airbox as the 03 Prairie, these things are a pain to install because everything has to go
inside the airbox. Before you start drilling holes in your airbox, make sure your air lines and fuel lines for the Dial-A-Jets
will fit without interference. Dial-A-Jets are worth it only if you are going to be riding at a lot of different elevations or
extreme temperatures. This is my personal opinion.
Hope this helps.
Old Sep 15, 2003 | 12:20 AM
ansible's Avatar
oxygen: you think maybe dyno jets are better then?
Old Sep 15, 2003 | 12:31 PM
Oxygen's Avatar
It's hard for me to answer that question, because I don't know how or where
you are going to use your bike. I chose Dial-A-Jets because I like to ride in Colorado
at 10,000 to 13,000 ft. Then I go home to Tenn. where I need different Jetting.
The Dial-A-Jets take care of this, but it is easier to rejet and cheaper ( Kawi jets or dyno jets,) and install 2 small washers ( 30 or 40 thousands) under your needles riding at anything under 2500 ft.
If you are riding at higher elevations, remove the small washers and go smaller on the jets.
Hope this helps
Old Sep 15, 2003 | 12:46 PM
XC800's Avatar
I have said it before and I will say it again. Get the ATACC system from Holtzman Engineering. Far superoir to the dial a jets. They will adjust for barametric pressure as well as alt and temp. We have been using then on our mountain sleds for the last 4 years. Nobody uses the dial a jets anymore www.holtzmaneng.com
STLyamwar
Jul 25, 2020 04:44 AM
Polaris-400
Aug 19, 2015 02:20 AM
Rob4092
Oct 24, 2003 01:37 AM
Oxygen
Feb 24, 2003 09:14 PM
