Raptor 01 vs Raptor 02 Trans
Old Sep 15, 2003 | 12:19 PM
RaptorOwner's Avatar
Default Raptor 01 vs Raptor 02 Trans
What is the difference inside the tranny?? My buddy and I have the same gear ratio, same tires, same motor mods and he beats me out of the hole everytime.
One more thing, his is an 01 and mine is the 02
Old Sep 15, 2003 | 12:44 PM
rennym's Avatar
2001 has wider ratios and a much higher 1st gear.
02 was adjusted because of complaints of a too high 1st gear, and reverse.
Use the search feature, you should find the exact ratios on this board somewhere.....
Old Sep 15, 2003 | 07:56 PM
ok, so second gear on up is the same on both years of bikes?
Old Sep 15, 2003 | 08:18 PM
wshrdskin's Avatar
No, 1st, 2nd, and 3rd are different on 02 vs 01's. 4th 5th are the same. The complaint was, at least mine, was the large gap between 1st and 2nd gear.
01 ratios.
Primary gear ratio 2.088
1st 2.428
2nd 1.526
3rd 1.238
4th 1.047
5th .904
02 ratios
Primary gear ratios 2.088
1st 2.583
2nd 1.667
3rd 1.286
4th 1.047
5th .904
The first 3 gears on the 02's are lower. The large gap between 1st and 2nd is still present but less noticable because 2nd is lower than second on the 01. jmo.
Old Sep 15, 2003 | 11:56 PM
Thanks wshrdskin!! So now I have something to go on. I got to get mine setup just in between cuz I know I wont be able to get it the same.
Old Sep 16, 2003 | 08:39 AM
garyc660R's Avatar
The 01 Raptor tranny utilizes torque more efficient.....you could try gearing up for better acceleration.....but it may hurt you in 4th and 5th.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
