need help with bog on low end!!
Old Sep 15, 2003 | 01:35 PM
cop's Avatar
cop
Default need help with bog on low end!!
I need help! When negotiating trails and slow areas I notice a pronounced bog when I hit an opening and punch it. This bog is only when the quad is in first gear and I have been going real slow. It doesn't happen when I start from a standing take off only from a very slow rolling start. Is ther a way to adjust my low speed jet? is it my float and or needle. If so how do I adjust those?
Old Sep 15, 2003 | 02:16 PM
MudStud's Avatar
You must have teh tm 45 carb??
Do a searh for bog.. You will have plenty of info.....
Old Sep 15, 2003 | 02:35 PM
scoddee's Avatar
Cop I don't have answers, just questions.Have you done the carb slide spring mod, changed the air filter type (paper,foam,gauze),altered the intake track in any way?How about exhaust,any changes at all? Have you put on taller tires?I believe any of these changes COULD affect low RPM response.Usually when you mod an engine/machine it's not a free lunch. Also what RPM are we talking here? If it idles at 1300, I doubt you should expect it to pull clean at WOT from a 1000 RPM lug!
Old Sep 15, 2003 | 02:54 PM
RoughRider01's Avatar
If its in the low RPM range that you are describing it could be that your air/fuel screw is set to rich or your pilot jet is rich. The needle effects the higher rpms and your main jet if i remember effects 1/4 throttle and up. Also, is your air filter nice and clean, have you changed spark plugs since you bought it??
RoughRider01
Old Sep 15, 2003 | 03:19 PM
MudStud's Avatar
Ok, before we all give advice,
What carb do you have? and or what mods?
Old Sep 15, 2003 | 07:06 PM
cop's Avatar
cop
I have stock carb,17 front sprocket, K&N with airbox lid on, heavier RWR clutch springs.
Old Sep 15, 2003 | 07:58 PM
QUADMAN650's Avatar
you bog is fom tall gearing and low idle speed
Old Sep 15, 2003 | 08:13 PM
buttfungus's Avatar
Yep, I agree! I like a 15t for trails.
Old Sep 15, 2003 | 09:44 PM
cop's Avatar
cop
Well how can I get rid off it?
Old Sep 15, 2003 | 09:57 PM
lilnotts's Avatar
are you still using complete stock exhaust? or do you have an endcap? if you don't i'd highly recommend it, i run 17t w/22", ya a lil bit tall gearin [img]i/expressions/face-icon-small-wink.gif[/img] i love it, ya it does bog but once you get used to its awesome, i love it, i can easily walk it from 1-3rd in a wheelie, 4th can be done but difficult
