this sucks a$$
Old Sep 15, 2003 | 09:19 PM
dirtrider078's Avatar
Default this sucks a$$
i finaly got my blaster running right and then i go do a burnout. not good, i pulled a damn good one but i think i blew somthing major. i shut it off and it was running fine but when i went to start it agian the kick start wouldent move [img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img] so i put the back end up on a block and tried to move the tires while it was in gear and nothing moved. i need to know weahter i blew my piston or my tranny
Old Sep 15, 2003 | 09:25 PM
BadNBlueRacer05's Avatar
Either broke a rod, broke your piston, or melted the rings to the cylinder.... either way its seized up.... take off the head and find out for yourself, or take it to the shop. Same thing happened to my blaster about 6 months after i had it.... damn stock piston cracked in two.
Old Sep 15, 2003 | 09:27 PM
On a simpler note... are u sure you're in neutral when you're starting it?... maybe a VERY simple solution to the problem... small stuff like that happens all the time
Old Sep 15, 2003 | 09:28 PM
i just put a knew piston in about 2weeks ago
Old Sep 15, 2003 | 09:29 PM
Well, you never know... but if that kick start isnt budging... something is broken
Old Sep 15, 2003 | 09:31 PM
warrior620's Avatar
Doesn't matter, I think you might be jetted a little lean b/c it blew when you were wide open right? Or you held the burnout to long long duration of high rpm's on an air cooled engine w/ no air flow= cooked rings or broke rod (I've seen this happen many of times).
Mike
Old Sep 15, 2003 | 09:42 PM
welll i think i seen some smoke come out of the motor if that helps
Old Sep 15, 2003 | 09:45 PM
lets see... hmmm. That smoke could be from... maybe gear oil getting on top of the piston from some melted/cracked rings? Did you say it was coming from the motor itself or the pipe? What color was the smoke?
Old Sep 15, 2003 | 09:49 PM
it was comming from the bottom of the jug and the smoke was white
Old Sep 15, 2003 | 10:18 PM
Man, that smoke might mean its sumthin really bad. I would DEFINATELY advise taking a look inside, thats the only way you will know for sure. Im not an expert on 2-strokes, i know the basics, but maybe a more proficient 2-stroker can help more than me. All i can say is take a look, man
