Help with pink spring installation
Old Sep 16, 2003 | 10:19 AM
Kramerica's Avatar
Default Help with pink spring installation
How and the heck do I get the center nut off so I can remove the original spring and install the pink spring? I put 265 fat pounds on it and it wouldn't budge. Also what do I torque everything back to?
Old Sep 16, 2003 | 10:59 AM
DirtyWhiteBoy's Avatar
The center bolt is reverse threaded. You'll have to put some big force on it clockwise now that you've overtightened it.
The torque spec is 69 ft lbs for the center bolt and 113 INCH pounds for the face plate.
Old Sep 16, 2003 | 11:18 AM
Kramerica's Avatar
Already knew that it was reverse threaded, still cant budge it. Thanks for the torque specs though.
Old Sep 16, 2003 | 12:11 PM
mjohnson97045's Avatar
I used a 1/2 - 3/4 inch wood rod about 1 - 1.5 feet long. I ran it through the clutch and wedged it agains the frame. This stopped the clutch from spinning and made it possible to get the bolt out
Old Sep 16, 2003 | 12:14 PM
04vforce's Avatar
the easyest way is to use an impact gun
Old Sep 16, 2003 | 12:20 PM
Kramerica's Avatar
tried an impact wrench(in reverse), and it would not budge. I hope it is not cross threaded, or seized.
Old Sep 16, 2003 | 12:37 PM
04vforce's Avatar
i think kawasaki overtihgtens them from the factory, i used an electric snap on impact gun and it came off no problem. let me now if your going to buy a pipe for your bike, i can get you a DMC ALIEN dual set up and the correct spring spring for 470.00
Old Sep 16, 2003 | 12:48 PM
Kramerica's Avatar
That is a real good price on the DMC's, but I've been thinking about the yoshimura duals, can you get a good price on them also?
Old Sep 16, 2003 | 01:25 PM
4wheelsRbetterthan2's Avatar
04vForce, that is a FANTASTIC price on Aliens with a spring. Can you PM me or send me an email (it's in my profile) so we can chat offline about the Aliens.
Thanks
Old Sep 16, 2003 | 01:48 PM
04vforce's Avatar
chris, im not too good w/computers and i could not find your email address my # is 619 843-7396
