Breeze Brakes
Old Sep 17, 2003 | 01:09 PM
Ruffy's Avatar
Default Breeze Brakes
I purchased a used 2001' Breeze that neededs new brake pads or shoes. I've purchase new shoes. Could someone please tell me how to replace the old ones. Much apprieciated.
Old Sep 17, 2003 | 08:43 PM
ftwflh's Avatar
Juist take your wheels off take the huds off there they are held together by 2 springs.POP them off put the springs on your new shoes like they came off snap them on put on huds and wheels adjust the cable (dont forget to run ALL the adjustment back in to get the huds off) you may need to tap the hubs over the new shoes.I just did front and rear today it took about an hr.Learn how to do this because a Breezr eats brakes up but other than that they are A GREAT little quad!!!!
Old Sep 18, 2003 | 07:58 AM
Ruffy's Avatar
Old Sep 18, 2003 | 08:05 AM
Ruffy's Avatar
Thanks ftwflh,
I did as you said, but hub seems to be stuck in place. Do I need a gear puller to remove the hub, or is there another way?
Thanks again, Ruffy.
Old Sep 19, 2003 | 07:59 AM
ftwflh's Avatar
be sure the adjusters are run all the way in and you may need to take a block of wood and a hammer and tap the hub on.
Old Sep 19, 2003 | 12:31 PM
Ruffy's Avatar
Great! Thanks again, Ruffy.
I see FLH in your name, what model? I own a SE-Road Glide 2001'.
Have a great weekend!
Old Sep 19, 2003 | 12:47 PM
BLASTERDEVIL2's Avatar
If you you want to make the breeze a little smoother get a cr80 shock for the rear.
Old Sep 19, 2003 | 02:39 PM
Ruffy's Avatar
Thanks for the info. Do I have to make any alterations or will the shock fit existing mount?
Old Sep 19, 2003 | 03:51 PM
I have never personally done it, but I heard it was a minor fab to the upper mount. I read it on this forum. I think it was in the "other atvs".
Old Sep 19, 2003 | 04:20 PM
RaptorOwner's Avatar
Yes I was the one who did the Breeze rear shock and it made a world of difference.
Now for your rear drum, if you cant seem to get them off they may be worn down to the metal and the hubs may need resurfacing at a local brake shop.
As for adjusting the brakes all the way in I would actually pull the cable out from the brake lever to make sure you have enough slack in it. If that still dont come off they may also be rusted on at the axle. Try some WD-40
