how do i adjust rear chain on 1995 425 magnum 4x4
Old Sep 21, 2003 | 03:12 PM
muddymagnum's Avatar
Default how do i adjust rear chain on 1995 425 magnum 4x4
I just got the bike not long ago , got a manual on order . I want to riding today & need to adjust rear chain . could someone please help .
Old Sep 21, 2003 | 04:45 PM
DustinMinnesota's Avatar
Loosen the bearing carrier bolts at the rear of the swing arm.
Take a punch stick it through the sprocket into the hole in the bearing carrier you will see it.
Roll the quad backwards until the chain is at the correct tension. Should have about 3/8" defection with you setting on it.
Torque the two bolts back to 45 ft lbs and your done.
Old Sep 21, 2003 | 06:06 PM
thanks dustin i appreciate the info
Old Sep 21, 2003 | 09:37 PM
Trestlenet's Avatar
Whoa... It is extremely important that you use a rope or strap to cinch the rear suspension down so the chain is at it's tightest tension. As the suspension lowers the chain tightens. You want the swing arm holding the rear axle to be horizontal with the ground. If you don't do this you may over tighten the chain..... catch some air and you may very well tear the drive sprocket out of the transmission. Iv'e heard of someone actually breaking off a chunk of the transmission casing...
Firefighter400
Oct 8, 2022 06:38 PM
95wolv
Jul 17, 2015 08:13 PM
WilliamBos
Jul 13, 2015 02:11 PM
rcappie4
Jul 10, 2015 04:54 PM
Rider252
Jul 6, 2015 03:37 PM
