Banshee wont run!!! NEED HELP!!!
Old Sep 21, 2003 | 05:14 PM
JakeDaSnake's Avatar
Default Banshee wont run!!! NEED HELP!!!
Hey, I posted a post to try to idle up my banshee and yall told me were the idle screws were and to turn um in for higher and out for lower, I was also runnin 24:1 gas/oil mix and yall told me to run 40:1 so I mixed some new gas and replaced my spark plugs...
now for the story, when I went to idle it up I saw that the THORS were loose on top of the carbs so I snuged them up and idled it up and now it wont run hardly at all... I have no idea whats wrong with it...
PLEASE HELP!!!!!!
AIM is WIGUNS
e-mail is Yota4x4@bellsouth.net
Later
Jake
Old Sep 21, 2003 | 05:27 PM
wildman77's Avatar
when you say it will hardly run will it idle by itself or do you have to use the gas to keep it running. you may need to adjust the air fuel mix screw i am not 100% sure but had to do that to mine once but i dont know if you have the same prob or not hope this helps
Old Sep 21, 2003 | 05:57 PM
warrior620's Avatar
40:1 is a little lean for summer riding, I run 34:1. Turn the screws all the way in and then back them out 1/4 at a time, I'm pretty sure my screws are like 3 1/2 turns out. Then adjust the air/fuel screws (flat-head adjustment) on the left side of both carbs. You'll need a long screwdriver to reach the right one b/c you have to come from the left side. With good jetting 'shee should run cherry w/ them 3/4 to 1 3/4 turns out. Also make sure you turn both of those equally.
Mike
Old Sep 21, 2003 | 09:33 PM
Ok I'll try the air/fuel mixture screws and I have to give it gas for it to idle unless the idle screws are all teh way in and then it idles high and backfires like crazy outta the right cylinder...
Old Sep 21, 2003 | 09:39 PM
warrior620: I tryed to talk to you on AIM twice but you wouldn't talk with me... just wonderin why cause I was just tryin to get help, I didn't mean to make you mad dude...
Later
Jake
Old Sep 21, 2003 | 09:56 PM
warrior620's Avatar
Jake: Thats strange.. are you sure you got the right SN (mystershee) b/c I never got a IM from you (wiguns is what your profile says).
Mike
Old Aug 19, 2010 | 08:20 AM
Banshee_3244's Avatar
Hey i need some help with my banshee all so pretty much the same as the other guy but my left side seams to be missing and the only way it will start is if i pray gas in the carbs the first time after that it will run like crap but not idle put new cool head on new plugs new reeds need help
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
