Anyone Convert an SP500 Rear Axle to All CV Joint?
Old Sep 22, 2003 | 10:29 AM
SurferSam's Avatar
Default Anyone Convert an SP500 Rear Axle to All CV Joint?
I'm interested to hear if anyone has converted their rear axles to cv joints on both the inner and outer. Any ideas?
SurferSam
Old Sep 22, 2003 | 11:32 PM
Traildog's Avatar
Take my advise and keep the U joints. Cv boots rip too easily and if not caught very soon your looking at a $300 + repair bill. U joints can be had for less than $20.
Old Sep 22, 2003 | 11:42 PM
425Xpedition's Avatar
All that is needed to convert to the cv's is the cv's. Pull the old shafts out and replace them with the cv's.
Old Sep 23, 2003 | 06:00 AM
ktxl's Avatar
Go to www.gorilla-axle.com check out the cv joint kits they have for atv`s .
Old Sep 29, 2003 | 02:45 PM
SurferSam's Avatar
I'll be more specific. Does anyone know what it would take to convert an older sp500 rear axle with inner and outer u-joints to an all cv joint axle assembly?
1. Are the wheel bearing carriers the same on u-joint sp500s and cv joint sp500s?
2. What parts must you buy inside the transmission gearcase to convert to the cv joint axle assemblies (new sprocket, chain, etc.)?
Old Sep 29, 2003 | 04:48 PM
The bearings, carrier and hubs are the same. No need to change anything in the tranny either. You just need two complete cv's.
Old Sep 29, 2003 | 10:09 PM
highwayman's Avatar
Why would you want to "U"-joints are bullit proof many friends of mine would rather have U-joints than CV joints because of the reliability of the U joints(you look after them and they will look after you) The new Sp 's just have two grease fittings. What would you do with all the time we spend in the garage build bird houses for our wives, just kidding I work with heavy equipment and grease and oil changes are the cheapest maintenance.
Old Sep 29, 2003 | 11:12 PM
Traildog's Avatar
When I had my 98 Sp with U joints I wished for CVs. I put over 2000 miles on those U joints (greasing after every ride) and were still original (except for one which was my fault). Now I have CVs on my 01 and have wrecked 2 boots trail riding. It's no fun replacing CV boots in a campground, but I did. Now I carry spare boots for the front and rear outers. You know what they say "be careful what you ask for".
STLyamwar
Jul 25, 2020 04:44 AM
snowolson
Aug 31, 2015 03:51 PM
Dammar
Aug 26, 2015 07:12 PM
DeFox500
Aug 14, 2015 05:59 PM
Rider252
Jul 6, 2015 03:37 PM
