97 scrambler Grinding
Old Sep 22, 2003 | 01:04 PM
mb012902's Avatar
Default 97 scrambler Grinding
It only does it when you give it a lot of gas. Other then that it is fine. Sounds as if the chain is jumping the sprocket. The chain and the sprocket are new and don't show any signs of abnormal wear. It kinda sounds like the gears in the gear box are slipping. There isn't really any metal shavings on the magnet for the fluid. The only mod that is done to it is a Hot seat clutch kit. Any help would be great.
Old Sep 22, 2003 | 06:22 PM
modquad's Avatar
If your drive chain and front sprocket are new (hoping rear sprocket is in good shape), it might be the drive chain inside of the trans. If you get a maint. manual, it's not a bad step by step, do it yourself fix.
Old Sep 22, 2003 | 06:44 PM
mb012902's Avatar
Thanks. I will have to check that out.
exmotocrosser
Sep 13, 2019 06:12 AM
flyin-lowe
Dec 1, 2017 03:18 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
