Mobil 1 oil querry an Racing gas dilemna
Old Sep 24, 2003 | 10:31 PM
sugarhead's Avatar
Default Mobil 1 oil querry an Racing gas dilemna
Just curious if I run mobil 1 15w50 in my Mojave will it make clutch slip?2 If I run Cam 2 110 octane in it on occasion an go back to premium will bike develop a SET to the higher octane an run like crap if I go back to premium 92 pump junk>I had a automotive teacher tell me that a motor will take set to the higher octane an then you will always have to run it or engine wont run right?
Old Sep 26, 2003 | 12:03 PM
trx250Rob's Avatar
Your are wasting money, cam 2 or any other high octane gas is going to do nothing for your performance, nothing. The only reason you would use hi-octane gas is if you had 12:1 or higher compression. The high octane prevents pre-ignition in hi compression engines but adds no power what-so-ever.
Also you quad does not build a dependancy on high octane. The reason it run bad on regular gas is that your have it jetted for the CAM2 which has a lower specific weight and runs richer. Go back to gas and rejet and save yourself a ton of money, unless you have a build engine.
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Sep 1, 2015 01:45 AM
