110 FUEL IN PREDATOR
Old Sep 25, 2003 | 08:42 PM
IE107's Avatar
Default 110 FUEL IN PREDATOR
IS IT OK TO RUN 110 FUEL IN A STOCK PREDATOR? I HERD THE FAN WONT KICK ON AS OFTEN
Old Sep 25, 2003 | 08:51 PM
BigBadScrambler's Avatar
You can but you are just wasting your money cuz unless it has high enough compression to need 110 octane, then it wont make any more power
Old Sep 25, 2003 | 09:04 PM
CountryJoeGlass's Avatar
It will make less hp with stock piston because 110 will burn slower. For your stock motor go with 91. Just my 2cents worth!
Old Sep 25, 2003 | 09:05 PM
Scotts88's Avatar
Ya know what i heard..if you type in ALL CAPS..ITS MORE HP! [img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 25, 2003 | 09:13 PM
scotts88 now it has less hp, thanks for the info!
Old Sep 25, 2003 | 10:04 PM
Doctor1's Avatar
Heh had the fuel cell foam come apart in my Camaro at the drag strip a couple weeks ago and ruined 12 gallons of 118 (can't use fuel with debris or take chance with it in a big nitrous motor could clog carb and then 706" big block would go blewy) so I filtered it and used it in the V force and could not notice no change what so ever no negative effects to hp or no gains basically I put 18.00$ worth of fuel in the V for
3 gal's.
Old Sep 25, 2003 | 10:19 PM
Thanks for the info Doc!
Old Sep 25, 2003 | 10:47 PM
Bill35's Avatar
The higher the octane the slower and colder it burns.Guys run high octane gas in high compression motors to heep from burning holes in the pistions.
Old Sep 28, 2003 | 09:19 PM
SubaruBaja's Avatar
by buddy runs 110 in his mostly becasue of the HotCam
PrairieDog126
Sep 12, 2015 06:53 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
Rooky
Sep 9, 2015 03:16 AM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
Elkaholic
Sep 6, 2015 02:44 PM
