86 300 bayou
Old Sep 30, 2003 | 12:12 PM
COWMANSAM's Avatar
Default 86 300 bayou
I parked it in the barn one dayand it was running perfect. A couple of days later it would not start. I tried to start it on starting fluid but it would not fire. The spark going to the plug looked a little yellow . I put a new coil on it, no luck. Any suggestions?
Old Sep 30, 2003 | 01:41 PM
kawrules's Avatar
The spark sounds fine you may try cleaning carb. Also take the fuel line loose right before it goes into the carb to make sure your getting fuel to it. (Make sure the fuel at the tank is shut off prior to this, after its loose turn it back on to check the flow). If this doesn't help try clean out the carb.
Old Oct 2, 2003 | 12:37 AM
Brushhog's Avatar
Usuallly It's fuel; fire or air.If not I would kill myself.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
wendal
Sep 15, 2015 01:50 PM
rcappie4
Sep 9, 2015 07:04 PM
