400ex running rich after jet
Old Jun 7, 2000 | 02:45 PM
chuck400ex's Avatar
I just got new plugs, and checked to see how my quad was running after i jetted to a 142 main (dynojet). I took the old plug out which was black as hell, and put in a new one (i check the size and all and i put in the same brand NGK, and same number) after about 10 minutes of riding with no holes in the airbox lid (i covered them up with duct tape), i took the new plug out, and saw that it was black too. the only part that wasn't totally black was the very tip of it. is it bad if i am running rich.... couldn't my quad blow up after awhile? Should i go to a 165 main (dynojet)? what do i have to do to prevent it from running rich, help would be greatly appreciated.
'00 4ooex w/ K&N power kit
Old Jun 7, 2000 | 03:55 PM
426ex's Avatar
stay with the jet you have in, uncover like 4 holes on air box and go from there.
P.S. the bigger the jet the richer it runs.
so the 165 would be way to BIG!
Old Jun 7, 2000 | 04:16 PM
400exalltheway's Avatar
yeah 165 is really big. i running 165 with white bros pipe and 7 1in. holes in my airbox
Old Jun 7, 2000 | 11:13 PM
chuck400ex's Avatar
ok, i uncovered 1/2 of the holes.. and i am still running a little on the rich side... is there supposed to be a thin layer of black powder on the plug? if i get a new silencer would I still have this problem? Correct me if i am wrong.. if i want to run less rich, then i add air... if i want to run more rich then I cover up more holes?? See i can fiddle around with it if i knew what caused richness or leanness. thanks for the help so far, i wouldn't have even been this far without it .
Old Jun 7, 2000 | 11:24 PM
nc400ex01's Avatar
ok to start with man, the bigger holes "more air" you get to the engine, especially having the k&n filter, you have to go bigger jet size to even out feul/air mixture...the stock size of the ex is 148 right? well, you went the wrong way....you needed to prob go to a 150...i bet that would have been the right jet.....the 165 is way to big...however, since you have holes in your box now, it may need 152 or maybe 155 but i wouldnt go over that....hope this helped!
Old Jun 7, 2000 | 11:35 PM
nc400ex01's Avatar
Old Jun 7, 2000 | 11:41 PM
RangerSX's Avatar
I'd help you out but it looks like these guys got you covered, if you ever need any help, email me, fordguy302@yahoo.com
later
Old Jun 8, 2000 | 05:22 PM
chuck400ex's Avatar
listen, the dynojets use different numbers.... so the 142 is a bigger jet than stock... and the 165 is a little bit bigger than the 142.. ok???
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
Bm400ex
Jun 22, 2015 09:16 AM
robj
Jun 15, 2015 08:45 PM
