jetting help!!
Old Oct 4, 2003 | 10:16 PM
scrambler123's Avatar
Default jetting help!!
I have a 39pwk carb, hpd pipe, k&n filter. I was running a 170 main my plug was always brown but when i pulled my piston out today it was partialy melted in one area it was definitely running lean (can anyone explain this) I am going to put in a wiseco piston reed spacer and a clamp on filter. What jetting do you think I should run now? any help would be appreciated
Old Oct 4, 2003 | 10:20 PM
IBlameTheDog's Avatar
Was your oil mixture OK? Many bikes have been ruined by faulty injector pumps or little or not mixing your fuel/oil properly. As far as re-jetting goes try it and check the plug that is the only way I know of getting it right.
Old Oct 5, 2003 | 01:19 AM
i was running polaris synthetic at 40:1 with premium
Old Oct 5, 2003 | 04:16 PM
anyone else?
Old Oct 11, 2003 | 01:08 PM
will someone please help
Old Oct 11, 2003 | 02:57 PM
CED's Avatar
CED
Is it the race pipe or trail pipe ?Which needle are you running ?Have you checked your jetting at 1/4,1/2,wide open ?Which plug do you run ?
Old Oct 11, 2003 | 03:20 PM
modquad's Avatar
Like CED suggested, check your jetting. I had to massage the needle on my 39. You might check with HPD and see, I know at one time they were looking into some custom tapered needles. Take your time when doing the jetting runs, it will pay off with a better running machine.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
