black spring + polaris black (42/75) in drive..wow !!!
Old Oct 5, 2003 | 12:29 AM
03twinbullet's Avatar
Default black spring + polaris black (42/75) in drive..wow !!!
I use to have only the black spring in the driven. good for belt life and take off but I had lost the upper mid and some top end.
now with this magic spring I have crazy take off and super mid and top end also instal the progressive supension front spring
I should have done this a long time ago it not the same machine anymore whitout fogeting the new ground clearence.
I was surprise with the confort that they procur even if they are way stiffer !
if that could help anyone !
Old Oct 5, 2003 | 10:35 AM
Prairiewrench's Avatar
So do tell,,, what are these springs and what difference have they made?
Old Oct 5, 2003 | 10:48 AM
DirtyWhiteBoy's Avatar
Put the stock spring back in the primary and do some timed test runs. Then put the new spring back in and repeat. We do 300 feet and 1/2 mile for top end. 1/4 mile would work too. Also, consider 2WD and 4WD runs if on loose ground.
Do as many test runs as it takes to get consistent numbers and then calculate the average.
Let us know what you get.
Old Oct 5, 2003 | 11:36 AM
well I guess you all know the black spring for the secondary pulley. and the other black spring comme from polaris
the effects where an higher engament (no rpm yet) and it brought the rpm down just where it needed it to be !
as if I put heavier weights ! whitout adding rotary mass. I should be instalint an exaust system soon ( but still hesitating supertrap,fmf or pro circuit... supertrapp is 300$ cheaper but i want as much performance as posible !
Old Oct 5, 2003 | 11:38 AM
with the exaust if I need more rpm I will instal 45g weights from the p360 (easy to find and also cheap)
Old Oct 5, 2003 | 08:56 PM
NovaKaw650's Avatar
75 pounds at 1.25" sounds awfully low. But maybe it's some sort of magic bullet that nobody tried before.
Old Oct 10, 2003 | 11:08 PM
prairievenom's Avatar
03twinbullet could you tell me if that black spring is a polaris spring or if it is an aftermarket polaris spring. If it is aftermarket wher did you get it.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 11, 2003 | 09:55 PM
I bought the spring at a polaris dealer for 27$ CD and I still like it alot I got use to the higher engament rpm
Gtsordo
Jul 13, 2015 10:38 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
coolguy420
Jul 10, 2015 01:17 AM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
