How Do I Do This??
Old Oct 5, 2003 | 09:23 PM
WishIHadA450R's Avatar
Default How Do I Do This??
If I were to put Renthals on a KFX400 w/ the pad on the crossbar:
How hard would it be to take off all the electrical components and the clutch and brake lever and the grips 2??
Where do you put the key hole and the oil light and neutral and the oil light???
All this is very easy to do right? Even for the people who are simply not too good at being "Mr. Fix-It??"
Old Oct 5, 2003 | 10:00 PM
Fusion's Avatar
Its easy to do on a 400ex, just unscrew the electictricals and levers, and take the bars off, then put the new ones on and screw it all back on.. as far as the lights go i have no clue i dont even know what a kfx lights are like, where they are, and all that stuff soo i hope this helps.. :-D
Old Oct 5, 2003 | 10:31 PM
thnx fusion...where did u put the key slot???
Old Oct 5, 2003 | 10:32 PM
300exRiderJay's Avatar
Well on my quad, the lights didnt need to be moved, and i don't see why they would need to be on a kfx. But as for taking off the grips, if yopu have an air compressor it makes it a lot easier. Pry up one side of the grip and spray air into it. It should pop up and be able to be pulled off easily. Mounting the stuff is also easy because all you do is unbolt it then bolt it back on
Old Oct 5, 2003 | 10:33 PM
Fusion's Avatar
The key and lights on the 400ex are on the front fender area right infront of the bars... so im not sure about on the kfx
Old Oct 6, 2003 | 01:54 AM
DaSandBomb's Avatar
i think you just bolt the bars down then put your key switch right back in the same place, ask the kawi forum.
kc
Old Oct 6, 2003 | 06:20 PM
mxquadracer's Avatar
I think you could get a better response in the kawi section (if you haven't asked already, I'd help you but I got an ex, not sure about the kfx.
