V-Force Backfires need help
Old Oct 5, 2003 | 11:10 PM
VNASTY's Avatar
Default V-Force Backfires need help
I run at sea-level,stock filter box,T-4 procurcuit pipes.V700 backfires when I let out of it from full throttle.Check the plugs,have dry black sut on them.Run super unleaded(Exxon) fuel.Do I need to rejet the carbs? Or is the backfire from the extra fuel from being on the rich side?The V700 runs BADA$$,Doesn't cut out on top,or drag in the mid.
Old Oct 5, 2003 | 11:48 PM
Vforcer's Avatar
I think the idle air screews need adjusted. ,,, likely needs turned out a bit
Old Oct 6, 2003 | 12:53 PM
XC800's Avatar
I would think you may be a tad rich. Stock jetting I presume. You can either try jetting down a size or 2 or try to open up the air flow going into the bike. K&N filter , open the lid of the air box see if it goes away. Allittle performance backfire is ok. I would think with pipes, stock jetting and sea level you should be ok in the jetting. But, plugs don't lie!
Old Oct 6, 2003 | 01:09 PM
green700's Avatar
I turned out my air screws on the carbs to 2.75 turns. Now it hardly ever backfires. Sometimes it does if I'm WOT then let off the gas and engine brake, but it's pretty rare now. I can engine brake all the way down sand sand mountain without any problem. I wonder how far out they can be turned at max.
Old Oct 6, 2003 | 01:11 PM
KevinM's Avatar
Pro Circuit should have a recommended setting for your mixture screws. If not, back the screw out 1/2 turn at a time until it goes away.
Old Oct 6, 2003 | 03:35 PM
VNASTY's Avatar
Thanks everyone for the info,will try ideas out this week.
Old Oct 7, 2003 | 10:05 PM
pulverized's Avatar
Where exactly is the mixing screw located? Is this sometimes reffered to as the air screw? Thanks.
Old Oct 7, 2003 | 10:08 PM
TRX500's Avatar
Don't forget to check for an exhaust leak............ fixed mine
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
