What to do next ?
Old Oct 11, 2003 | 01:31 AM
1fst700's Avatar
Default What to do next ?
I have a v-force 700. It has a pink spring installed and a black spring also. I have also installed a set of pro-circuit T4 exhaust. Also a DG v-pro fat series front bumper and rear grab bar A arm guards. Also AC nerf bars with black webbing. C series rims with stock fronts and 20x11x10 Maxxis razors rears. I have not jetted just adjusted to get it running ok. I live at about 800 to 1000 ft above sea level. I have just ordered a hpd plain spring. I have no air box mods.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 11, 2003 | 10:12 AM
nyroc's Avatar
Dual airbox snorkles.
Rejet. Rejet. Rejet.
Remove carb heater hose.
Old Oct 12, 2003 | 04:31 PM
1fst700's Avatar
thank you for the information i took of the snorkle this morning and that helped take out some all of the popping when i let off the throttle. can you recomend a jet size at 800 to 100 feet above sea level?[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 12, 2003 | 05:24 PM
1fst700's Avatar
also how do you remove carb heater hose and what if any is the side affect positive and negitive? again thak you for your information!!!!!
Old Oct 12, 2003 | 07:27 PM
nyroc's Avatar
I don't have a 700, can't recommend a size for jets.
The carb heater detracts from performance a little (I hear). I have had many machines benefit from cooler intake air. I just havent done it to my 650.
The heater prevents icing in snowy weather. My 650 will sit and idle without dying when the snow flies better than other quads. It could run just like the other quads if I removed it.
Old Oct 14, 2003 | 05:31 PM
XC800's Avatar
With just pipes, I would recommend going to 140-145. BUT!!!!! You have the output in the pipes, now you need the dual snorkels. See my post earlier re Home Depot Vac hose. And of course the K&N filter. Rocky Mountain has them 40 bucks. Pipes work best if you have increase input as well as a better filter. I installed the TPI adjustable vents just to give me more air at higher elevations. With all that, I would bet at 1000 ft you would want to be around 145-150. Keep an eye on the plugs as well.
Old Oct 18, 2003 | 02:35 PM
1fst700's Avatar
What is Alltoys Stage 1 Kit? Also can I get one? Also how much if I can. Thank you for all your help.
I have read some of Alltoys posts and really is full of information!!!!
