what kinds of gains should i be expecting from a stage 1 hotcam
Old Oct 13, 2003 | 02:20 AM
AustinONeal's Avatar
Default what kinds of gains should i be expecting from a stage 1 hotcam
should it be faster on top end and midrange if so how much where will i see the power gain at. can i tell a difference once i install it. will it hurt my low end?
Old Oct 13, 2003 | 09:02 AM
XTraptor's Avatar
yeah I wanna know too. I am thininking about just the cam, I mean I want to keep the bottom end untouched. can I do that? what kindda gain would that make? if I am only replacing the cam, I won't need to remove the head, right? I know alot about cars, but ATVs are new to me.
thanks
Old Oct 13, 2003 | 10:31 AM
BigScary's Avatar
the biggest gain u will see will be in the midrange
but mine still has the power to wheelie in ANY gear.......so I don't feel like I lost ANY bottem end.....
heres my review.......same bottom end as stock, Tons of midrange gains, and a lil gain on top
not as much on top as I need, I guess it's a good thing that the stage one is being replaced by the stage two right now
BigScary's Avatar
Old Oct 13, 2003 | 10:37 AM
sixsixT's Avatar
I put in a stage 1 and I don't think I gained much but I'm still playing with the jetting. So far I liked the stock cam better.
Old Oct 13, 2003 | 11:00 AM
CaptBags's Avatar
So am i to believe that after pipe and, jet kit a cam is not the next good performance upgrade? Are they hard to put in? What else would you need,, Valves, springs, or, are stock ok?
What is the difference between stage 1 and, 2?
Old Oct 13, 2003 | 11:19 AM
PatsRaptor's Avatar
I ran the stage 1 and also ported head and 12.1 piston so it just wasn't the cam by its self but got alot of mid range and a good amount of top but if you drag race you might want to go with the stage 2 for the more top end!
Pat
Old Oct 13, 2003 | 11:37 AM
sixsixT's Avatar
You can use the stock springs with the stage 1. No they're not hard to put in but that would also depend on your ability. I think I got more gains with my dual K&N adapter, but like I said I'm still playing with the jetting and the gains would probably be more noticable with a 11:1 piston and some porting.
Old Oct 13, 2003 | 03:58 PM
kuz28's Avatar
i was told to add a 10.75/1 JE (high Compression) piston with the Stage1 Hot Cam to increase my mid and top range. I just completed the install (as well as an 02 tranny upgrade). Just as soon as i break it in properly...i'll post my opinion on performance.
Old Oct 13, 2003 | 06:06 PM
BigScary's Avatar
I had the same setup.......it have me some good gains.....I really liked the Midrange grunt that the higher compression gave me......
but it didn't have enough top end for me.......I had to go to the 686 11:1 stage two cam.........
Hopefully I'll like it better......but who knows.....
