LT80 front wheel spacers?
Old Oct 14, 2003 | 03:03 PM
CrowleyOffroad's Avatar
Default LT80 front wheel spacers?
Thinking about widening the stance of my daughter's LT80. Has anyone used wheel spacers?
I found a set from Graydon Proline: http://www.graydonproline.com/
Or can I just get a different offset wheel?
Any suggestions for front tire wheel size & brand (currently19x7x8)? She mostly rides in the sand, but does ride in the dirt a bit, so I don't want sand only tires.
Thanks,
Jon
Old Oct 14, 2003 | 08:50 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
James Lucky sells long A-arms for the LT80. I put Turf Tamers on the rear, and it widened the back end considerably, but I wouldn't say they are the ultimate sand tire. Sorry, can't remember the tire or rim size, but I think I got them from James Lucky also. Nobody recognized it as an LT80 when I was done!
Old Oct 14, 2003 | 09:39 PM
I saw the a-arm extenders on the JL website, but not a-arms. Do they actually have a-arms too?
Jon
Old Oct 14, 2003 | 09:51 PM
hajimoto684's Avatar
Yes they do make +3 a arms for the LT 80, I bought my daughter a set for racing and that thing is very stable, as far as the turf tamers for the rear they are a little wide and can break the cases, so I was told. I have a new set of them on rims though if you want a set!
Old Oct 14, 2003 | 09:56 PM
Here is the package JL has for LT80 Tires:
Kits contains two 20x7:00x8 Cheng Shin tires mounted on two Douglas .125 polished aluminum rims for the front and two 18x9:50x8 Titan Turf Tamer tires mounted on two Douglas .125 aluminum polished rims for the rear.
Code: KT80
Price: $230.00
Are the Turf Tamers wider than stock? What is this about breaking the case?
Old Oct 14, 2003 | 10:44 PM
bsb64's Avatar
Here is a link to the J Lucky setup.....
http://www.jlatvproducts.com/Merchan...duct_Code=KT80
Old Oct 14, 2003 | 11:48 PM
Red Rider
Don't get the Cheng Shin fronts! They will make the bike push real bad in turns.
Old Oct 15, 2003 | 07:00 PM
RickyA's Avatar
JL Lucky Front End Extender Kit $150. Widens the Front 6 inches. ITP Holeshot Tires 18X10X8 Rear (nothing cracks or breaks) / 19X6X10 Both sets mounted on T-9 Rims. Also go with a K&N Air Filter for the LT80 (fits inside the stock airbox) and go with an FMF Fatty Pipe & Power Core 2 setup. Cheap way to make the bike wider, perform better, sound better, and even look better. Also you can put AC Nerf bars on this little dude.
Old Oct 15, 2003 | 10:18 PM
Your on your own about the cases! Just remember that you cant just buy one side! My 2 cents! [img]i/expressions/face-icon-small-smile.gif[/img]
To be old and wise must first be young and stupid!
Old Oct 16, 2003 | 01:02 AM
fishslab's Avatar
Here is what I just did to mine today to widen the front. I flipped the wheels, plugged the old valve stem holes with JBWeld and drilled two new ones on the oposite side. That gained me an inch per side. Next I knocked out the wheel studs and put in 3" long bolts and two nuts per bolt on the wheel side as spacers. I had to grind a little off the sides of the head of the bolts so they would fit in the stud slot. This gained me one and a half inches. Total gain per side 2.5 inches. Total cost 6 dollars. Total time 2 hrs.
