does any of yalls quads slip out of gear once in a while?
Old Oct 15, 2003 | 11:22 PM
roosthrower's Avatar
Default does any of yalls quads slip out of gear once in a while?
it seems that once in a few rides my blaster slips out of 5th and goes into 4th. is this normal? also sometimes when i am drag racing my blaster and shifting from first to second it goes into neutral and makes me have a crappy drag. is this normal too and does anyone have any tips on how to avoid hitting neutral when shifting from first to second?
Old Oct 15, 2003 | 11:51 PM
BigScary's Avatar
all I can say is pull up harder......LoL
a couple times my rappy got between 3 and 4.........I just started pullin harder and it hasn't happened again........[img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 16, 2003 | 12:11 AM
96Southpaw's Avatar
I do that alot.. You need to start in second gear if you can while drag racing.. If you keep falling into netrual that will run the tranny... If you cant start in 2nd get a lower sprocket so you can. Thats what I had to do.. If that dosent fix it and its falling out of gears alot that means the forks are bent and its not staying in gear.. That isnt good either.. Just thought I would put in my 2 cents
Old Oct 16, 2003 | 12:35 AM
warrior007's Avatar
Adjust your shiftlever down a tooth or two before you run into problems.
Old Oct 16, 2003 | 02:36 PM
yfsrider's Avatar
mine has slipped from 2nd into nuetral a few times
Larry S
Jul 4, 2015 12:54 PM
winterwolf
ATC 3-Wheelers
Jun 3, 2015 07:34 PM
Jiggypete
May 30, 2015 07:55 AM
