4X4 Not working, WILL THIS WORK??????
Old Oct 16, 2003 | 12:15 AM
polonda's Avatar
Default 4X4 Not working, WILL THIS WORK??????
Ok, i have a 1999 Sportsman500 that the 4X4 hasnt worked in for about 3 years. After all this i know that the hubs arent getting any power. NO one can tell me why but they arent. So i am going to run a hot from the battery to a switch and then to the hubs. If i energize the hubs wont it kick in the 4X4? I have thought about all the reasons not to do this(4X4 being kicked in all the time, and all that) thats why i am putting in the switch, only use 4X4 when i get stuck anyways. Are there any reasons this wont work? Please someone with more knowledge than me let me know if i am about to F&*( this sportsman up.
Old Oct 16, 2003 | 01:41 AM
savage21's Avatar
Save your pains ,bring it to the dealership, or is you have a manuel,jsut start trackign the 4wd system fro mthe hub up
could be anything,from a bad 4x4 switch tobad connections,..........decribe your problem more like from when you hit the 4wd button tolooking at the hubs
Old Oct 16, 2003 | 07:22 AM
polonda's Avatar
I have had it to 3 dealerships. They all keep it for about a month, scratch there heads and say they have never seen anythinglike it before. Love the machine, but at my wits end and want 4X4 to work. When u engage the 4X4 it does nothing. Have had a meter on it and cant find where the break it. Only getting .5 volts to each hub. Replaced the switch, 2 sensors, and a wring harness. $500 and 3 years later, No 4X4. Was wondering if the direct 12 volts would work? Thanks.
Old Oct 16, 2003 | 12:01 PM
lovemud's Avatar
I'm not sure about your model, but there should be circuit breakers in pouches, they have a tendancy to get wet and stop working. Do you have a service manual? if so it shouldn't be hard to trace the circuit either back to a problem in the wiring or the control module.
Old Oct 16, 2003 | 12:57 PM
KevinM's Avatar
If the magnetic coils inside the strut housing are weak or bad, your fronts will not engage.
Old Oct 16, 2003 | 05:40 PM
56chevy's Avatar
OK, don't laugh. My 99 Sportsman 500 with about 200mi quit working in 4x4.
If I remember correctly, the speedometer didn't register correctly either!
I took it to the dealer and they replaced the speedo($150) and that fixed the 4X4 problem!
I still don't understand why, but it worked.
Hope this is some help.
David
Old Oct 16, 2003 | 05:49 PM
spewy's Avatar
Old Oct 16, 2003 | 06:06 PM
lovemud's Avatar
I think the control module is part of the speedo.
Old Oct 20, 2003 | 09:50 PM
polonda's Avatar
OK, does anyone out there have the diagnostics to go through the 4x4 and figure out whats wrong with it. I bought a repair manual but the one i got didnt have it in it. I know some do. Would greatly appreciate it.
Old Oct 20, 2003 | 10:51 PM
DustinMinnesota's Avatar
Has the quad had the switch changed in the shifter?
If not I am a betting man the board is not recieving the power for the 4X4....
Also check to see if the switch on the tranny is getting power when in forward gear...
